Every single glow plug dead or am I retarded???? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-13-2012, 09:26 PM Thread Starter
Ok so e99 f250 7.3 auto, starting in aug/sept here in bc temps still hovering 15-20 Celsius harder and harder starting, got batteries tested at work, the starter doesn't work, ok take it apart get the auto electric place to silver solder new brushes on the Mitzu starter 30 bux whatever and they even took the solid inch (exaggeration) of grease off and sandblasted and painted everything including the inside of the houseing. Starter cranks hard for the first couple days get batteries tested still good, starter starts taking longer to start late oct maybe I didn't clean the sludge when I put the starter together take it to the guys that did the brushes they took it all apart sand blast paint and new solenoid $70 later good hard solid crank but the motor takes a lot of cranking to et going and I start cranking it till the battery goes dead day after day get the batteries tested again good I know the starters great cause is been rebuilt and bench tested. Ok why is it doing this bring out the dvom 12 volts hot side GPR and 12 volts on other side when key is on for the 1 or 2 mins whatever it is now I'm testing gp on the open terminal on the valve cover using the battery as a ground the block whatever I consistently get 0 on my auto range dvom it goes from 0.L on the display to 0.000 when connected to the glow plugs....every single one on both banks
Are all the glow plugs really bad? Would one nearly dying glow plug make the truck fire up for a little while? Till it finally died completely not allowing the motor to start without a ton of cranking?
Things to keep in mind :
*glow plug looked good when I replaced an injector a few months ago not a bunch of ashing or swelling
*the previous owner said he replaced the glow plugs just before I bought it so ill age them between 1 and 2 years
*i am able to get the truck started with lotssss of cranking in the 0-10 degree weather we have now
*in these extended cranking periods I do give it quite a bit of throttle
*yes it's quite smokey when it finally starts
I've finally got it back in the driveway and I'm plugging it in tonight to see if that helps for the morning just looking for insight on the situation thanks.
E99 F250 7.3 - intake, strait pipe 35" mud terrains 6.5 procomp lift ...that's all....for now
nodd89 is offline
post #2 of 4 Old 11-14-2012, 06:25 AM
Quoted: 184 Post(s)
Feedback Score: 3 reviews
You're right, No Chance they're ALL bad...
I'm confused as to what you're saying here though "why is it doing this bring out the dvom 12 volts hot side GPR and 12 volts on other side when key is on"
Are you saying the voltage drops when the GPR throws? If so, and it will be a dramatic drop, that would indicate to me that, at least, some of the GPs are Certainly working!
I'm not sure of what the trouble is with your resistance measurements, but, something's wrong if that's true.
If you don't see any difference in voltage, then they're Not in the circuit and drawing the Big amperage they should.
NoRalPh is offline
post #3 of 4 Old 11-14-2012, 07:06 PM Thread Starter
What I meant is a one-side of the glow plug relay always has power to it and check the other side of the Glow plug relay it only has power to It when keys on For the minute or two minutes cycle there is a voltage drop in the vehicle I have not measured it with the DVOM but the lights definitely dim as well as the volt gauge on the dash does go down when the relay is active
nodd89 is offline
post #4 of 4 Old 11-15-2012, 06:19 AM
Quoted: 184 Post(s)
OK, so it sounds like they're working,,, the GPs draw close to 200A when first activated and that's a dramatic load to the system that would be hard to miss.
Plugging it in should help a lot, also switching away from 15W oil to a 5W synthetic helps in really cold weather too if you're using it.
NoRalPh is offline
