fuel pump not getting power why - Ford Powerstroke Diesel Forum
Old 11-07-2012, 08:36 AM
Angry fuel pump not getting power why
fuel pump only works when i jump it straight off the battery has a low circutry code and tps code replaced the tps still nothing any ideas?
Old 11-07-2012, 08:44 AM
Have you looked at the Inertia Switch behind the pass kick-panel? What about the fuses?
The relay, on an '02, is located in the fusebox and considered "Non-Serviceable" (and rarely, if-ever has trouble).
Next, is the PCM running (it's what controls the pump)? Do you get a WTS light when you first roll-on the key?
How's the Instrument Cluster? Are the gauges working?
Old 11-07-2012, 05:22 PM
yes checked the fuel shut off switch it was fine checked fuses, also good, pcm working fine but no wait to start light also had a low circut code for the fuel pump fyi this is all after we had the cab off doing a complete rebuild if we jump the fuel pump it starts and runs fine but has no throttle im really stumped on this one
