Truck is sluggish from dead stop/low rpms - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-03-2012, 07:59 PM Thread Starter
Tivs's Avatar
if i stomp on it from a dead stop or lower rpms (low turbo spool) it seems like it shifts to soon or something. if i wot from like 2k rpms it takes off and pulls me in my seat. it also sucks for towing its hard to pull at lower rpms but once it gets going its fine. im also straight piped. is it my ebps? also my exhaust is ghetto from previous owner...he left in the original 2.5in tube from turbo to like end of cab then in turns into a 3in then turns into 4in (i did the 4in and ran it out the side) would that effect it?
SOLD: 99.5 F-250 ECLB, Zoodad mod, aih delete, 22k mod, wix 46637,16.5s wrapped with 35x12.50 BFG T/As s, ccv mod, 140v IDM, heater core ball valve mod, 324,000 miles
95 F-250 ECLB, E4OD, 3in turbo back straight piped, diy intake w/ 6637 and riffraff prefilter, cool go fast stickers, 140v idm, need new ball joints and king pins...negative camber is out of this world. 266k miles
Tivs is offline
post #2 of 3 Old 11-03-2012, 08:55 PM
the exhaust size shouldnt cause a negative effect. You are decreasing back pressure with the larger exhaust, so i dont think that is where your problem lies.
jackinggear is offline
post #3 of 3 Old 11-03-2012, 09:06 PM Thread Starter
Tivs's Avatar
ill try unplugging my ebps tomorrow. sometimes the turbo sounds like its dumping early like 10 (idk i dont have a gauge) but then i get a violent shift almost like the truck is compensating for the sudden loss of power.
Tivs is offline
