New water pump nothing but problems
As i said just put a New...well reman but now the truck squeaks im assuming itsunami the pump and i can't get the thermostat inlet to seal I've done everthing. i got it down to it only leaks when on the throttle. Should it swell when it warms or should i try rtv red...or em i gonna break down and take the pump back
thermostat inlet i used form a gasket to stop leak been fine scinse
ya didnt know how u guys felt about rtv red or anything. well let the truck warm up and so far no leaking....so either the gasket swelled or when the thermostat opened and well followed the path of least resistance. but i just started it now and its been sitting for idk 4 hours id think the thermo would be closed and it didnt leak. also washed my motor since coolent was all over it, it squealed for ever finally went away just as i pulled up to the house and to be honest the truck sounds smoother and quite......idk if i was already use to the squeal or what. its been nothing but issues this week so im on edge
found these on autozones website but they said they had nothing like this along with carquest
Compressor Works/Water Outlet (815558) | 1999 Ford F250 Super Duty P/U 4WD 8 Cylinders F 7.3L Turbo Diesel | AutoZone.com and this one Compressor Works/Water Outlet (815001) | 1999 Ford F250 Super Duty P/U 4WD 8 Cylinders F 7.3L Turbo Diesel | AutoZone.com |
well if anyone runs into this problem, they discontinued the gasket for the 7.3, but if you ask for it for 1995 ford taurus 3.0 its the same gasket. i still have a pully squealing could it be from the coolent getting into the bearing?
probably belt squeal/chirp
get some liquid soap and spread it on both sides of the belt wher you can reach let it dry and see if the squeal is gone |
dont matter now dang thing is leaking again. i give up. its time to bust out rtv black
