electrical problem?? - Ford Powerstroke Diesel Forum
Old 11-03-2012, 03:11 AM
This is the second time in a month. The first time it shut down I had a cam position error code PO340 so I replaced it but it still wouldnt start and then randomly did??? It did the same thing this morning but had the cam position code and ICP code P1212 voltage not at expected level. After several attempts it started, luckily before I killed the battery... Any help would be greatly appeciated!
If it makes any differance I'm running a edge evo programmer set on race......
Old 11-03-2012, 07:00 AM
remove the edge, then see whAT IT does
