No wait to start light - Ford Powerstroke Diesel Forum
Old 11-02-2012, 07:38 AM
Hey guys, I bought my truck about 2 months ago (2002 7.3 177000 miles on it) and I noticed when i bought it that the "wait to start" light doesn't come on. I never really thought anything of it until last night the truck had sit for 24 hours (it was about 50 degrees out) and it had a hard time starting....usually fires right up. Any reason why this light wouldn't come on? Bad glow plug relay? If it is, what are some aftermarket unit that will hold up to the demands of the glow plugs?
Old 11-02-2012, 07:49 AM
Is it throwing a CEL? Might want to get a scanner and see what's up
Sent from my iPhone using Autoguide.com Free App
Old 11-02-2012, 08:40 AM
no check engine light....i'll see if it throwing a code tho.
Old 11-02-2012, 08:44 AM
Check that usually it would throw a code saying what glow or if the relay is bad. Can you hear them clicking when you turn the key?
Old 11-02-2012, 04:16 PM
Super-non-technical answer... The lightbulb behind the Wait to Start light could be shot. You should hear them click though once it's warm.
Old 11-07-2012, 05:27 PM
i had this problem b4.. there is a fuse under the dash panel 20 something mabey 22 or 23 but im not sure... it could even test ok..mine did.. was getting a bad connection tho i would definitely start there assuming your battery and connections are good that is
