99 powerstroke gallops at idle when cold - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-01-2012, 12:41 PM Thread Starter
glanzerf250's Avatar
Have you guys ever had yours gallop at idle from a cold start? It will gallop for a minute or 2 then it will smooth out after it is warm. IF you have it plugged in it will not gallop at idle (since its warm).
Any ideas?
Pickup is a 1999 with 260k on it.
-Dave
2002 F250 7.3L w/ 141k
straight pipe, AFE stage2 intake and DP-tuner and only gets 18mpg
glanzerf250 is offline
post #2 of 3 Old 11-01-2012, 02:43 PM
Gallop as in jerk arounds when your driving it. OR are you talking about it romping? A cold diesel is gonna run poorly. Until they get up to temperature a.) the internals contract due to the cold and can cause a small loss of compression. B.) the combustion area is cold and hinders compression ignition. And c.) the oil is cold and has a higher viscosity which is more difficult to move which hinders injection because our injectors use oil pressure.
With the block heater in your are removing these variables. Mine has a pretty rough idle until it reaches operation temps.
Im still pretty new to the whole powerstroke game but it sounds like you can chalk it up to just having a cold engine.
jackinggear is offline
post #3 of 3 Old 11-01-2012, 03:59 PM Thread Starter
I will agree with the majority of ur reply. The thing is we owned the pickup since new with 16miles on it. I have read could be the injector sleeves to the high pressure oil pump.
-Dave
