Help, Tons of white smoke and oil coming out from ccv mod hose and smoke from tail pi - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-30-2012, 08:00 AM Thread Starter
CenCalDually's Avatar
I went up a 10-15 mile mountain pass doing about 55mph and boosting about 25psi and egt's where 10-11 and right after i got to the top the truck started smoking white smoke from tail pipes and lots of white smoke and oil from ccv mod hose. I lost about 3 quarts of oil through the ccv hose in about 100 miles. I noticed it idles rough even worse when i put the chip back to stock and loss power on my take off. or low rpm's and egt's where getting a little higher because lack of power. There's no check engine light on and I have no way of checking codes. I was told it could be a stuck injector but could that cause alot of crank case pressure to spill out that much oil.
2000 Ford F350 Dually, 8.5" Donahoe Lift, MBRP Cool Duals Exhaust, DP Tuner, AFE 2 Intake, T500,Turbonetics 6.0 IC, BTS Valve Body, PI Torque Convertor, HPX Line, DI UpPipes, Mag Hytec Diff. & Trans Covers, ISSPRO Gauges, Turbonetics 6.0 InterCooler, 2 Tru Cool Trans Coolers, Van Turbo w/ ATS Housing, 05-07 Front End, 08 Mirrors & Tailgate, ITP Fuel Regulated Return, ITP Tank Mod & Fuel Filter Bowl Delete, Dieselsite Coolant Filter
CenCalDually is offline
post #2 of 2 Old 10-31-2012, 06:15 PM Thread Starter
No help, nobody had these issues?
