Yet another no start...
Problem; early 99 powerstroke will crank and crank but won't start. It pukes out lots of white smoke that smells like diesel.
Things I've tried ; New UVCH harnesses New stancor gpr New motorcraft glow plugs (less than a year old) Ran autoenginuty and get codes for cylinder 2, 4, 6, 8 low side open and banks 1 and 2 high somethin or other on the injector buzz test. Any thoughts would be much appreciated Sent from my DROID2 GLOBAL using AutoGuide.Com Free App |
Codes are 1272 1274 1276 1278 high to low side open. Idm shutting down that whole fuel bank?
You've probably got a bad UVCH connection somewhere. Maybe the engine side pigtail. RiffRaff has those and you splice in the connector to old wires.
Hopefully not a bad IDM |
Uvch harness are all good. All new and engine side has been thoroughly inspected. Will 1 bad injector cause the idm to shut a whole bank of injectors off?
Anybody got a fresh idea? Goin to clear codes and reset computer soon to see if I can get it running long enough for a contribution test. Just to see if I got a bad injector
yes one injector can shut down a whole side if a solenoid is shorted , no need to run a contribution test if it doesnt pass buzz test , work on that part first , just for the record , after every buzz test you should clear the codes or youll keep getting same codes every time , will lead you down the long road to correct diag , resistance test all solenoids on that side and see what the readings are
Good to know! Learn somethin new every day. Ill see what the resistance is and post up some numbers when I get them.
Well checked out all 8 injectors through the UVCH. All measured between 2.9 and 3.4ohms. So I'm assuming all good. Any other thoughts?
One thing I forgot. It also came up with codes 1293 and 1294 left and right side banks open. Starting to lean towards a cooked idm but not sure yet.
Gonna track down a idm to swap in here soon. Hopefully that'll awnser some questions
