01 7.3 misses on any cold start - Ford Powerstroke Diesel Forum
Old 09-26-2012, 07:45 PM
Unhappy 01 7.3 misses on any cold start
hi there. Im at my whits end with this f450 new injectors new glows gpr and passanger side uvch It has the oil crossover hose from head to head. The issue is when started it runs on around 5 cyls all the drives fire but the passanges till you let it warm up than open it up fully to redline in 3d gear it clears than runs like a champ all day till cold again. started cold i have unpluged the passanger head wiring and it keeps chuging unplug drivers it falls on face and dies warm runs the same with one or the other off. when i had the passange side valve cover off i left it over night and the dam thing started perfect that morning so i replaced that harness and gasket thinking i moved something. well its still the same missing when cold what could it be Any help is great help
Old 09-26-2012, 09:17 PM
try synthetic oil yet? Possibly when installing the vc, you hit something and now problem back. Did you do the 50 cent mod?
Old 09-27-2012, 06:19 PM
Unhappy
running rotella oil did 50 cent ommed the uvch and drivers side was around 6.2 to 6.6 when still conected to inside passenger side was 3.4 to 4.0 didn't make sence. keep getting code p1316 ran a buzz test and 4 worked loud and 4 where quieter but scanner didn't tell us any more. also tryed my bro's idm out of his 99.5 and no difference his ran mine just fine.
Old 10-01-2012, 06:00 PM
COME ON GUYS someone's been here before i can't be the only one????
Old 10-02-2012, 06:23 AM
I'm having the same problem, although I haven't replaced the glow plugs(they checked out good) or the injectors (I didn't want to spend that kind of $ not knowing for sure if I had a few bad ones). Started a thead a few days ago without much help either
Old 10-04-2012, 08:25 PM
CEL light on? Have acces to AE?
