Is this Safe Mode? - Ford Powerstroke Diesel Forum
Old 09-25-2012, 05:53 PM
Is this Safe Mode?
I accelerated normally from a stop light and lost power. The engine was still running but at idle speed. Pressing the accelerator had no effect. The service engine soon light was on. I pulled over and restarted the truck and it ran normally the rest of the way home (about a mile). Service engine soon light was off. Its a 2000 F250 Super Duty 7.3 with 152K miles. This was the 2nd time it happened.
Is this what is described as "Safe Mode". Is there anywhere I can go for a list of possible causes. I will have the engine scanned for codes. Can anyone tell me if the Advance or Autozone scanners will work on this engine. If not, what do I need.
Old 09-25-2012, 06:39 PM
Those stores can't scan it.
You might have a throttle position sensor issue, under valve cover harness issue, or many other things. Safe mode is rare on these.
Auto Engunuity is amazing
I made my Samsung SGH-I997 send this.
Old 09-26-2012, 04:26 AM
If you cant afford AE, go to Ford or a local diesel shop and have it scanned. Sounds like a TPS though.
Old 10-02-2012, 04:30 PM
I bought a Superchips Vivid Linq and can now scan for codes. So far, the problem hasn't recurred.
Old 10-02-2012, 05:16 PM
You may or may not get a code. Live data is the best way to tell
Old 10-02-2012, 05:23 PM
The 2000 F250 Super Duty seems to have very few PIDs available through the Linq. How else can I get live data?
Old 10-02-2012, 05:50 PM
Maybe it's the Linq that won't monitor much.
What all does it give you?
Old 10-02-2012, 06:01 PM
I have to hook it up in the truck to see but it was only 1 page of items. The TPS was definitely not included. The ones I remember are: Vehicle speed, RPM, oil Temp, boost, exhaust pressure and some injection PIDs, There was also nothing related to the transmission.
I searched but couldn't find anything for a complete list of the PIDs available on the 2000 F250 SD, so I don't know if its the Linq or just little data available in that model year.
Does anyone have a link to the PIDs that should be available?
Old 10-03-2012, 03:56 AM
Superchips = Super****s
Old 10-03-2012, 04:00 AM
Not much help. I still need to know what PIDs are available on the 2000 F250 SD 7.3.
