Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 10-18-2007, 11:00 PM
paulmacjr paulmacjr is offline
Unhappy oil leak
ive got a 96 with 90,000 power stroke 4x4
its got a good oil leak from the motor and as i opened up the engine compart ment i noticed it look like there was in the valley of the motor there was a little collection of oil and there is all so a noticable oil stain on the ground when parked for a while. from what ive heard is it could be the turbo o rings and other suggestions before i have to pull the turbo off and repalce the o rings?
Old 10-18-2007, 11:39 PM
Blue01F250 Blue01F250 is offline
Tournaments Won: 1
that or hpop o-rings...
Old 10-20-2007, 11:04 PM
how much time and labor do you think it takes to repace these o rings? on the hpop and the turbo ?
Old 10-20-2007, 11:13 PM
forddieseltweek forddieseltweek is offline
You will be hating life if you have to remove the turbo!!! ITS A PITA!!!
Old 10-21-2007, 12:04 AM
this is going to be one of those jobs that make you what to bring it to ford isnt it? dang this is going to be a pain in the but job
