smoke at idle: Injectors, bad turbo??? blown motor??
Ok guys, my powerstroke is smoking at idle, light white smoke at idle and turns into a cloud of smoke. It seems to go away at speed and returns at idle.
I removed my driver side injectors and noted all 4 injectors as AD. I also noted the middle oring to be hard and smaller than the groove? Could it just be orings?? Maybe a leaking turbo? I push the turbo and feel no play in it, but I guess a seal could be leaking? I did not note a loss of oil from my truck. Would a blackstone lab be helpful? If diesel in in my oil I got bad compression, correct?? Here is pictures of the injectors out of my truck: Please help me trouble shoot it... ![]() ![]() ![]() ![]() ![]() ![]()
I have the same problem, leading me to believe that my injectors are dirty. Bump cause i got the same damn thing
I see some discoloration where your injector sits in the tube, look at the brass sleeves close and make sure they aren't cracked
I don't think those are the correct o-rings in the middle section. I replaced 3 sets of injectors in my truck, and all of them were round o-rings, not square o-rings.
Buy an O-ring kit and check that out.... Thats my thoughts |
After years of use the o rings form to whatever shape they're placed in. The tubes are flat walled and that's why the o rings get flat on outside edge. I would replace the orings before re installing them or I"d buy new alliants and put them in.
