7.3 Dead miss and rolls the coal...... plz help
Hey guys I have a 2000 7.3L that seems to have a dead miss to it and puts out a lot of black smoke at times. If standing in front of the truck the engine idles smooth but if standing at the rear or in the driver seat it has a dead missing sound that none of the 7.3's Ive owned have had.. The miss will clear out as driven but still sometimes has it through the low end range. Also while driving around 10mph it will have a small "lunging" feel and will even lose pedel sometimes driving up the road like you just unhooked the pedal off the truck?.. Truck has oversized injectors(not sure what size:/ ),edge juice att,5inch exhaust with muffler turbo has around 80k on it. I drained the fuel bowl and it seemed to help a little for a bit. I think Im gonna change the oil and fuel filter tomorrow and see what happens. Does this sound like one of the sensors?Icp?Ipr? Maybe even the fuel transfer pump? Sorry such a long post,Thanks!
So I changed the oil and filters and it seemed to help some. Then got to thinking,accelerator pedal sensor? So I wiggled and pecked around on the acc pedal sensor and it seems to not be idling as bad but I can't say for sure of that is the problem. Can a acc pedal sensor cause this slight dead miss and touchy touchy gas pedal? Pedal also will just go dead while driving sometimes. The codes that came up when I checked them was p1211? And the p0221 acc pedal sensor. Any suggestions to what I need to try next? Thanks a lot
Did you do the mods to the truck? did this problem start after the mods?
I would think with bigger injectors, you should probably be running a custom chip from someone like TW, PHP, DP, Swamps, etc. That might be causing the misfire sound. As far as the ACC sensor, I think you can hook an Ohm meter to it (while disconnected) and slowly go from idle to full throttle and see if the meter has a nice smooth change in numbers. If it jumps around then the sensor is likely bad. I was also thinking that these trucks have another switch on the ACC pedal for telling the PCM when the pedal is at idle. I could be wrong on that one though. |
No I did not do the mods if I had done them the edge would have never been around it lol I have plans on selling the edge an buying a dp.
Yeah I will prolly try that then with the meter,are these prone to go bad? and yeah I believe your right cause there are two switches on the pedal for some reason,wonder what that idling sensor would be called? Thanks |
Well, getting rid of that edge could resolve most of your complaints.
the intermittent "no response" from the acc pedal is probably different though. I have no idea what the other switch is. I haven't really heard of the tps going bad but it is possible. |
Could it be possible that the cam sensor be causing this pr
Could it be possible that the cam sensor be causing this problem? It was replaced before me with a parts store sensor. . . .
It is a possibility. Fairly cheap to replace. It seems that it is hit or miss on getting one that actually helps the engine run smooth.
Yeah thats true I am gonna get that ''parts store'' cam sensor off there and toss this edge on CL. I just hate to throw 65 bucks at it and not know if that will fix anything. And I started to notice something else the other day,my battery light started coming flickering like the alt plug was lose or something well yesterday the batt light came on and stayed on and well now my alternator is shot... Wonder if that could have anything to do with this idling issue? thanks
CPS is only around 20 bucks the last time i saw. Go to an International dealer and order one. It should be blue and I have heard good things about it.
Glad you are dumping the edge but you will probabaly need a different chip to run the truck with the bigger sticks. The alt. problem might have contributed to the running issue so maybe fix that first and see what it does. |
