Late 99 no power
Here is a run down of what has happened over the last couple of days.
I had ordered a FRx upgrade from Riffraff and had finally got around to putting it on and now I have issues. It runs and idles fine but has no power at all. You can open it wide open and has no power, takes a while to even get to 30mph. Here is a list of things that I unhooked or took off and had to reattach/put back on. HPOP Reservoir Fuel Lines that connect to fuel bowl Fuel Bowl Assembly Cold Air Intake I made sure to put everything back on the right way, that includes all lines and wiring plug ins. |
If you let air into the fuel lines/injectors it may just take a while to purge it out. How much have you driven it like this? I let air in one time (ran out of fuel) and it took 8-10 miles to clear the air out.
I probably drove it maybe 5 miles. I'll go drive it some more in a few mins and see if it straightens out.
Straightened right out man. Thanks man
Awesome glad to hear! Glad I could help. You'll surely be able to pass the knowledge on I'm sure.
