No insturments, No Throttle.... Please Help - Ford Powerstroke Diesel Forum
Old 07-18-2012, 12:16 PM
Hey Guys,
I have a 2001 F-450 7.3L
Problem = No Power to Instrument Panel, Throttle not responding.
After reading on the Fourms I found the root of the problem was an Exposed/Frayed Wire for the OD Switch in the steering Column.
I taped up the wires and replaced the #45 10amp fuse, however I'm still having the same problem but now the Fuse is not blowing out.
Before I could replace the fuse to fix the problem. As a Temp Fix so I could get it back to my Shop.
Anyone have any ideas?
Old 07-18-2012, 01:16 PM
Have you read through this:
https://b7445ba3-a-62cb3a1a-s-sites....attredirects=0
(it's got wiring diagrams and stuff in it...)
Old 07-18-2012, 02:07 PM
had the same problem on my 02 250 i repaired the od wires with no luck ran a code reader and it turned up as a tps throttle positioning sensor luckily for me it was just the fuse i needed hope that helps
Old 07-18-2012, 02:58 PM
Thanks for your responses guys.
All Fuses are Good, The TPS was replaced about 3 months back, and the Instrument Cluster is still non responsive.
Doe's anyone have a complete wiring diagram for the Model and Year?
My Mobile Diesel Mechanic and I think it is a problem with the fuse box? any thoughts?
Old 07-30-2012, 08:46 PM
I had the same problem on my 01 Super Duty, when I would push OD it would kill everything had to replace entire clock spring to fix problem in addtion to shifter
