Unidentified component making funny noise - Ford Powerstroke Diesel Forum
Old 07-15-2012, 10:43 AM
2000 7.3L - Noticing a very noticable rapid pop-pop-pop-pop-pop (at least 3 per second) from this... sensor...? with the ignition key on, engine off. Using AllDataDiy, I was not able to figure out what this is (the one with the green connector on it, on an induction tube, one of the plastic lines goes to the turbo.) Is the sound I'm getting normal?
Thanks
Old 07-16-2012, 03:37 PM
That's the solenoid that controls the wastegate. Can't say I've heard any noise coming from the one on my truck.
Old 07-17-2012, 05:11 AM
Thanks, that gives me something to go off!
Old 07-20-2012, 12:56 PM
Confirmed with the dealer P/N is F81Z-6C673-AA, turbo control solenoid. Anyone else get any noise from this part? If failure is imminent, I'd prolly spend the $50 for a spare
Old 07-22-2012, 03:32 PM
I noticed that just last night, sounds like one of those aftermarket universal fuel pump, probly normal
Old 07-22-2012, 03:41 PM
It's not normal, but idk why it'd be popping.
Old 07-22-2012, 04:14 PM
The sound mine was making sounded like a pump of some sort, maybe a diaphram pump and the wastegate runs on a vacuum line, so that sounds normal to me
Old 07-22-2012, 04:27 PM
There is a vacuum pump to operate the 4WD front hubs and air vents in the cab, but the WG is operated of engine vacuum, not the pump.
Old 07-22-2012, 05:13 PM
the wastegate has a red vacuum line that goes directly to the pump/solenoid we are talking about. there is also a green vacuum line that comes off this solenoid that goes to the intake just after the filter, so maybe this solenoid is a valve that regulates vacuum coming off the intake?
Old 07-22-2012, 05:37 PM
The green line is the vacuum supply off the intake pre turbo.
The red line is the vacuum supply for the WG actuator.
Do you know what a WG does?
