2000 Powerstroke Loss of Power and change in engine "tone"
Looking to get some advice from the Pros on this great site. I have had my 2000 F350 for 5 years now and have had very little trouble from the truck. I bought it with 80K and now has 230K. Lately I have had a problem with the truck losing power when accelerting. It is intermitent and usually happens just after taking of at a stop sign etc. The truck will lose a lot of power and accelerate very slowly for a couple of seconds and then suddenly snap back to normal. When it loses power the engine also gets very quiet and dosesn't chatter like it normally does. It doesn't jerk or act goofy, it just accelerates very slowly and smoothly even with the pedal on the floor and then like I said it snaps back to normal and takes off. I am nothing of a diesel mechanic and only know of basic maitenance etc. so go easy on me. This has been the best truck I have ever owned and really don't want to buy another. Any help would be greatly appreciated. Thanks, Jason
I forgot to mention that this happens at all times throughout the day no matter the temperature of the engine etc. Thanks, Jason
sounds like the back pressure tube maybe clogged up and the back pressure sensor maybe bad.... just a suggestion get a mechanic to put a scanner on your truck to diagnose your truck first
Thanks so much for the help. I live in a very small Arkansas town and nobody close to me has the ability to scan a Powerstroke. I have to drive an hour and leave the truck over night to get a scan. The truck has been acting like this for about a month without the check engine light ever coming on so is it possible a scan could still show an issue without the light on? Thanks, Jason
Yes. Not all codes will throw a light.
So I ran into a small bit of luck today. A friend of a friend had a Superchips programmer that doubles as a code reader for my 7.3. He slapped it on for me this morning and it showed two different codes. The first one is P1670 and the second one is P1211. The scanner does not go into detail concerning the codes and only gives the numbers I just listed so I have no idea what they mean. I am going to do a search and see what I can find. Has anyone run into these particular codes before?
I'm not familiar that close with the codes off the top of my head but a google search always turns up lots of info.
The 1211 is ebpv if I remember right, which can be caused by a chip. Sent from my Autoguide iPhone app |
i notice on a few programmers i seen they only able to scan just a few codes (if i'm not correct on this information please correct me), i got a mechanic with a Snap On scanner to scan mine which gave more codes then my programmer gave me.
It almost sounds like your ebpv is sticking.. when it's running right, unplug your ebpv plug and see if that helps out. It would be free to try.. just a thought.
Sent from my DROIDX using AutoGuide.Com Free App |
I did a search and found that EBPV stands for Exhaust Back Pressure Valve and I understand the basic function of the valve but I do not know where on the engine it is located. Can you give me an idea and maybe a description of what it looks like so I know what to look for?
