2000 7.3L kills when I take turns
So here is the thing, I have a 2000 f-350 7.3L. i was having problems with hiccups while driving down the road and the truck killed on me once while I was turning.
I changed out the cps which took care of the hiccups while driving but now if I do not power break while taking a turn the truck will kill and start up just fine. As of now I have the batteries disconnected to see if that will reset any problems. Any ideas ?
i have the same problem on a box van i have. anyone??? im looking into it.
scanner says this.. on mine icp 1.08V ICP KPA 4764, ABOUT 800 PSI OR SO, ITS 13,000 KPA AT W.O.T. LIKE 2000 PSI OR SO IPR 8% IDLE AND 26% W.O.T. SCES 6.8V AND ITS OPEN VFDES 23 VPOWER 13.8V VREF 5V EPC 8.75 IDLE 10 W.O.T. FUEL PWS 3.45 IDLE 2.73 W.O.T. CODES P0113 P1000 P0603 P1316 P0677 ITS LOOKING LIKE THE UNDER V.C. HARNESSES Last edited by trqjnky; 07-13-2012 at 08:30 AM. |
check the flimsy nut on the IPR
I'd check the UVCH in both those cases.
Yeah. Sounds like a mechanical connection is loose.
