7.3 -02 f250 died, then starts, runs normal and dies again - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-05-2012, 04:45 PM Thread Starter
I was out driving then the truck suddenly dies, like turning of the key. Tried to start it again, it cranks nicely but won't start. Tries to start it a couple of times with no result. After 15-20 minutes it starts again and runs normal. I drive back home and leave the truck idling, 4 minutes later it dies again the same way. Tries to start it again and starter runs slower until the starter melted.
I've ordered a new starter but why did the engine die in the first place?
2002 F-250 PowerStroke SD CC SB Lariat 4x4 7.3
Rilli_Chefen is offline
post #2 of 7 Old 07-05-2012, 04:48 PM
SuperCrutyPS's Avatar
Quoted: 298 Post(s)
Garage
Have you replaced the CPS (Cam Position Sensor)? Ford issued a recall on them because the truck would shut off, but start back up.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is online now
post #3 of 7 Old 07-05-2012, 05:05 PM
Start with a Ford or International (for T444E) CPS....and if that's not it I'd look into IPR.
The_Pats_Fan is offline
post #4 of 7 Old 07-05-2012, 05:26 PM Thread Starter
looks like the CPS newer been replaced. if the CPS is bad will it only die when it idles ? will the CPS often fail with warm engine?
the color of the CPS is black if it does matter ?
post #5 of 7 Old 07-06-2012, 10:10 AM Thread Starter
Changed the starter and CPS today but the problem still remains. Starts and runs good for a while then just dies. After a couple of mins it starts again.
Where should I continue troubleshooting? Where is the IPR located? Are there any other sensors that could cause this problem?
post #6 of 7 Old 07-09-2012, 02:17 PM Thread Starter
some updates
went by a friend who is working at ford, he doesn't know much about PSD:s unfortunately (They are NOT common i sweden)
but we hooked it up to "Ford IDS" and find 9 (!) error codes (no idea how old the are)
1. P0340 CMP Sensor Circuit Malfunction
2. P0500 Vehicle Speed Sensor (VSS) Malfunction
3. P0603 "battery disconnected"
4. P1280 ICP Circuit Out of Range Low
5. B1203 Fuel Sender Circuit Short to Battery
6. C1284 - Oil Pressure Switch Failure
7. B1483 Brake pedal circuit input failure
8. U1027 indicates no RPM data is being received
9. U1262 is a communication bus failure
the first code i guess is for the CPS and that is brand new and didn't change a thing.
number 4 is the most interesting i think, ICP Circuit Out of Range Low. that must mean that the HP-oil got really low ? if it gets low i think it would be one of three things
1. IPR is sticky and let go of all pressure.
2 leaky injector o-ring.
3 HPOP reservoir empty.
i suspect bad IPR, Im out driving, lets off the pedal, IPR decrease pressure and when it should increase pressure for idle i don't, it sticks and the engine cut off, after 30min the IPR have cooled down and the IPR "unsticks" and it starts... What do you guys think about that theory ?
7. B1483 Brake pedal circuit input failure. is a bit confusing to me, i know that every time it shut down my foot have been on the brake pedal, coincidence ?
Ideas ? Thank for your patience!
/Rilli
post #7 of 7 Old 07-15-2012, 05:51 AM Thread Starter
Changed the IPR, Now it works !
