Help, white smoke, vibration, loss of power
Cruising down the highway and truck just lost almost all power and started vibrating pretty violently. Pulled over and let it idle, was idling a little rough and was blowing white smoke. Ran an injector buzz test and everything came back normal so it isn't the UVCH. Pulled the codes and got a p1280 and p0470. I know p1280 is ICP sensor could that be the only problem? truck can't even get out of its own way.
any input?
I have the same problem. Ran fine after work taday n went to go eat and it wont barley move
Did you find out what your problem was?
I'm having the same problem to. Dropped it off at a local shop, should haventheproblem found tomorrow.
Let me know what you find out, my mechanic is out of town until Monday
Mine did this today on me heading to town.
Sent from my Desire HD using AutoGuide.Com Free App |
I had a new PCM put in mine, ran fine that day for a few hours. Started it today and took a dump again. Now it's time to go fishin for problems
i had the same issue with my 2001 f350 it started to run rough with blowing white smoke out the exhaust, it was showing all kinds of codes when i got a mechanic use his scanner, found out the pick up line inside the fuel tank have a crack in it, as long i keep the tank above 1/4 of a tank or more my truck runs fine.... going to repair the pick up line later on
