anybody have a clue? - Ford Powerstroke Diesel Forum
Old 06-22-2012, 01:13 PM
Help
Old 06-22-2012, 01:41 PM
Is that Oil or Fuel?
Look above the passenger tire for a 3/8's metal tube against the motor. It is the fuel bowl drain, controlled by the yellow lever to dump water from the bottom, and there are O-Rings that rot and cause it to leak. If that's it you can simply re-ring it!
Old 06-22-2012, 01:43 PM
It's oil...
Old 06-22-2012, 04:00 PM
oil galley plug on the back of the head has a o-ring on it. pull plug replce o-ring install plug no more oil leak.. could also be the oil line to or from the turbo.. most of the time it is the o-ring on the plug.. hope this helps
Old 06-30-2012, 03:41 PM
is it hard to take plugs out? do i need to pull anything to make room?
Old 06-30-2012, 03:48 PM
Tons of oil leaks that it could be. Clean it first, then get up top in the valley at the front, and work your way back looking for where the leak starts.
HPOP, HPOP lines, HPOP plugs, HPO rail plugs, EBPV actuator rod where it exits the turbo pedestal, turbo pedestal orings.
