running rough - Ford Powerstroke Diesel Forum
Old 06-12-2012, 08:25 AM
running rough
hey guys,
i have a late 99 PSD 190k, straight pipe, 6-pos power hungry chip, 6637 intake.
it has been running rough so i did o-rings on the injectors, at first it ran a bit better but now it is running rough at idle, almost like it is missing a bit and has a tick from idle through all rpm. it still has plenty of power and black smokes a ton. any ideas? thanks.
Old 06-12-2012, 08:36 AM
Have you ever had to replace tour injector harness plugs? I had the same issue a while back
Old 06-12-2012, 08:40 AM
yes, i have replaced them. they are ok.
Old 06-13-2012, 06:54 AM
Send a message via Skype™ to helgaairhead
Originally Posted by tgarrisoniv View Post
hey guys,
Mine is doing exactly the same - just like its missing as you say and Ive also noticed the tick at idle.
PSD 2001 - 225' Km on the clock, should be plenty left.
Helge
Old 06-14-2012, 09:29 PM
I had something similar wrong with mine and it was a bad injector and a bad wiring harness. Hope this helps..
Old 06-15-2012, 03:46 AM
yeah, im leaning towards a bad injector...
Old 06-15-2012, 06:31 AM
i thinking it is #8. i am going to pull off vc and unplug each injec, one at a time and see if i can find the culprit!! anyone had luck trying this?
Old 07-01-2012, 09:26 PM
It may be easier to disconnect each wire individually from the harness clip so u dont need to pull the vc. Just an idea. Ever find the problem ?
