2001 7.3 with a 1999 7.3 engine - Ford Powerstroke Diesel Forum
Old 06-08-2012, 12:09 PM
truck idles at a really rough lope almost liike its going to die, but accelerates faster than with my program and is blowing a lot of black smoke. i just put a new computer in it and recently put a new turbo in it
Old 06-08-2012, 12:10 PM
it only does this after about 10 minutes of running also. the computer that is in it has never been programmed
Old 06-08-2012, 12:24 PM
Check your UVCH connectors see if their burnt.
Old 06-08-2012, 01:35 PM
where are they located
thanks for ur help
Old 06-08-2012, 03:33 PM
Under the Valve covers
Old 06-08-2012, 03:34 PM
Or check your cam sensor
Old 06-08-2012, 04:19 PM
Or the ICP.
Old 06-08-2012, 04:42 PM
i just replaced the cam and i know my icp is bad it is throwing a code but would that cause it to haul *** like it is. its pumping a lot of fuel. could the icp cause that
Tags
black smoke, high rpm's, rough idle
