Injector issues? - Ford Powerstroke Diesel Forum
Old 06-02-2012, 11:26 AM
Injector issues?
So i started my rig up this morning, as i pulled out of my gf's drive way i noticed my idle was a little rough ( like when you have that resistor mod ). i also noticed that my "service engine soon" light was on. As i drove home, everything seemed normal (EGTS,Fuel Pressure,Boost,Temp,Volts) didn't even notice any loss in power. i got on the HWY and hammered on it... then all of a sudden the service light went away.. and the idle was back to normal
did one of my injectors just pass through a kidney stone? :hard:
-165,000Miles
any feed back would be great!
Old 06-03-2012, 08:30 AM
Bump! Same exact thing happened this morning. I'm gonna get a scanner on it tomorrow..
Old 06-03-2012, 01:07 PM
pretty sure injectors are fried..
-loss of power
-only drivable in 1st and 2nd gear
-smoking like a freight train
-barely idles
had it towed to bd diesel in Abbotsford BC. i guess ill find out more on monday..
Old 06-03-2012, 02:29 PM
Get a good scanner on it and retrieve codes. If the light came on, with the right tool, you can find what's out-of-spec to guide you. Do a "Buzz Test" and you can retrieve IDM codes as well as evaluate the injectors.
