What's causing this (video) - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-02-2012, 07:24 AM Thread Starter
Once you go black......
CanadianDiesel's Avatar
Send a message via MSN to CanadianDiesel
The turbo sounds like its searching for air...only does it when RPMs are somewhat low. Any ideas...
Then & Now
Matt
'99 F-350 4x4 7.3L
6637, 4", chip; far too many upgrades to list.
Coming soon: Rigid Industries Lighting, Nav, On-Board Air.
Latest mods: Line-X, '08 Black Leather Captain Seats (Lariat), Trans, EGT and Turbo Gauges; TS chip, Chrome Delete.
02 VW Jetta TDI - 40mpg
CanadianDiesel is offline
post #2 of 9 Old 06-02-2012, 06:00 PM Thread Starter
bumping this up...is this something i should be worried about?
Then & Now
Matt
'99 F-350 4x4 7.3L
post #3 of 9 Old 06-02-2012, 06:01 PM
Tmoney511's Avatar
Did you check all boots?
03 6.0 f250 180k, 20" XD Hoss rims, 33" tires, boost, pyro, tranny temp, fuel psi, AirdogII 165, FASS sump, Edge CTS monitor, MBRP straight piped 6" miter cut blk stacks, k&n air intake, SCT w/ Eric's extreme street/extreme x, RECON smoked side mirror turn signals, 05-07 Banks Techni-Cooler Intercooler, Pmax turbo, ARP head studs/FCDP full EGR delete/modified intake manifold, Sinister Coolant Filtration, 12k 55w HID heads/12k 35w HID fogs
Tmoney511 is offline
post #4 of 9 Old 06-02-2012, 06:10 PM Thread Starter
Negative. IF it it's one (or more) boots how can I prevent them from leaking again?
Then & Now
Matt
'99 F-350 4x4 7.3L
post #5 of 9 Old 06-02-2012, 06:50 PM
Tmoney511's Avatar
While checking all boots pay real close attention to detail. Sometimes the rip on a boot is at the bottom and very hard to see. It definitely sounds like a suction noise. It's almost like a waste gate. That was my first thought on the noise. Boots tend to rip from old age or if the boot slid off just make sure the clamps around the boots are tight and everything is fully connected. Does your boost gauge fluctuate at all?
post #6 of 9 Old 06-02-2012, 06:53 PM
Quoted: 3 Post(s)
sounds like turbo is in need of a rebuild or a ww..
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #7 of 9 Old 06-02-2012, 06:55 PM
Tmoney511's Avatar
Yeah if all boots check to be fine I'd go with this.
post #8 of 9 Old 06-13-2012, 08:33 AM Thread Starter
Boost gauge does fluctuate, it bounces back and forth about 5PSI... Gave the boots a quick check, seemed ok. Will maybe pull them off and inspect
Then & Now
Matt
'99 F-350 4x4 7.3L
post #9 of 9 Old 06-13-2012, 08:49 AM
STANGMAN893's Avatar
The blue boots are really common coming off the turbo with the slight bend and the drivers side cac black plastic tubes are known to develop cracks in the flex part.Just some of the ones I have seen frequently.
STANGMAN893 is offline
