Oil leak need some advice - Ford Powerstroke Diesel Forum
Old 06-01-2012, 04:23 AM
Send a message via AIM to White7.3stroker
Okay for the last couple days i have noticed a oil leak which i thought was from my drain plug..but i got under it last night and checked the drain plug and it was tight..so i noticed it was coming from the side of the pan and it looks to be coming from where the dipstick goes in..what should i do i took a few pictures of what it leaked overnight..and i also just did a ccv mod if that matters..thanks guys!
Sent from my DROID X2
Oil leak need some advice-uploadfromtaptalk1338553414982.jpg   Oil leak need some advice-uploadfromtaptalk1338553428072.jpg
Old 06-01-2012, 04:31 AM
u can try tightening the dip stick nut. Go easy though. Bob at DieselOrings has a repair kit for the dip stick
Old 06-01-2012, 04:33 AM
Dipstick tube flange oring
Dipstick Tube O ring - Inside the pan
Dipstick Flange Oring Repair
Old 06-01-2012, 04:34 AM
Okay thanks i will try that! I wasnt sure if it was a gasket or a oring behind there..i was just getting worried my ccv mod might have been why it was leaking for some reason ..
Old 06-01-2012, 04:48 AM
Originally Posted by jesilvas View Post
Thanks gkr the links jesilvas did you get your orings from ford? If so how much were they?
Old 06-01-2012, 04:39 PM
Okay guys got the old oring out and the new one will fit inside the old one!! Do i have the right one?!?! Help
Oil leak need some advice-uploadfromtaptalk1338597552387.jpg   Oil leak need some advice-uploadfromtaptalk1338597560995.jpg
Old 06-01-2012, 04:54 PM
Yep, those are ford packages in my write up.
Did you get the PNs that were in my thread? If so, it's right.
The old one is probably swollen with oil.
Old 06-01-2012, 05:03 PM
Yea its the same number i just wasnt sure and hated to put it back together with the wrong oring!! But i got the oring in there im gonna try and put some rtv on the nut before putting it back on..should i put oil back in it before i put the starter on to make sure it dosent leak? Thanks yall have been alot of help!! I would have been lost otherwise!! Also my nut was lose when i started to take it off but figured id change the oring since i was already there..my nut seems to be flat i wish id got a new nut but would have had to wait till monday...
Old 06-01-2012, 05:35 PM
Oh, I left oil in it. It isn't up to that point until it's slung around by the rods.
Knowing what I know now, I'd RTV around the hole and maybe a little on the inside of the pan around the new oring.
Old 06-01-2012, 05:46 PM
Okay well i got her put back together just giving it a little time for the rtv to set up..and yea i wasnt sure about the oil so i drained some out of it..but with fingers crossed i hope we got it fixed! Thanks for the help!
