truck stalling
My 2000 7.3 has been stalling on me lately. It doesnt seem to matter when. I can be going 50 which is dangerous cuz the steering wheel locks up or i can be completley stoped. ive had to run it low on diesel quite a few times which i dont like to do, so could it possibly be fuel filter? Or bad wiring? Sometimes the check engine light goes on when it stalls sometimes it doesnt. Sometimes the battery light comes on as well. Any ideas on what the problem could be?? thanks
I had a similiar problem recently but it turned out that it had to do with my gauge wiring that I had just completed. I had it hooked up to a circuit that I found out tied in to my PCM I guess even though the fuse diagram said different.
I would start with your fuel filter and maybe even check the pressure on your fuel pump. It might be giving weak pressure intermitently but I could be wrong. If you can get your hands on a code reader and hook it up, the next time it quits might trip a code for you. Just a shot in the dark though. |
Thnx those were going to be my first 2 options before i started pickin at other stuff. if anyone else has ideas plz share
What kind of a stall? A stumbling stall or a key off kind of stall?
Really can't help until we know that. The steering shouldn't lock but it may be very hard to steer with all the weight and big tires ans such |
I doubt its fuel filter or fuel pump. Could be CPS, electrical issue, etc Oh and how easy is it to start back up? |
its just a key off kind of stall. sometimes it starts right back up, if it doesnt right away ill wait about a minute if that and try again then it will start. sometimes itll shutter a little real quick while im driving but it wont stall
and thnx guys
Thanks for the starting this tread as I have a exact same issue with my 2000 F350 7.3. I am no trying to hijack this ... but my symptoms are the exact same so maybe between both out trucks we can figure this out with the help from the forum.
My stall is the same ... just like turning the key off. Here is what happens and maybe this will determine where to start looking. I also have another issue which might be related that I will explain at the end. 1. Truck sits for a day or so, start up ... no problem no check engine light. 2. Notice my GPR relay (new white rogers installed) does not trip (have LED light mod) but get wait to start light (no LED from relay light) 3. Will drive 20-30 miles or more ... no problem no CEL 4. Truck will sputter or hick up for sec while driving like it loses power or fuel but then continue on but now the CEL comes on and stays on. This may happen again or not. 5. 5, 10 or 20 min later while driving no matter how fast ... the truck just shuts off like the key was turned off. While still rolling (I have a 6 speed) I turn the key to off position the turn to crank over, GPR LED mod light comes on and it starts right up and away I go. 6. CEL is still and will stay on. 7. I get home to read with OBDII reader and says "0" Codes Let truck sit over night ... start it the next day ... no CEL for at least the next 20, 30, 50 miles until it hick ups again 8. It will eventually stall again but it could be 50 miles, 100 miles or 30 miles. 9. Read with OBDII and says "no codes" Do I have the wrong code reader? It a standard OBDII $65.00 reader. The other thing I mentioned above was the GPR. I am mentioning this cause it might be related. I replaced all my GP's and installed a new GPR (White Rogers) and then also installed the LED mod to tell if the GPR is working or not since I have learned that "Wait to Start" is not tied to the GPR, but comes from the ECU. so here is series of events; 1. Truck cold (live in NC) turn key, Wait to Start comes on, no GPR LED 2. Truck starts with a little white smoke, colder it is more white smoke 3. Drive truck or let it warm up till temp gauge has moved. 4. Turn off ... restart and now GPR LED comes on. 5. GPR LED will work every time when the truck is warm. 6. Let truck sit until "cold" Over night ... all day, whatever 7. Start truck ... no GPR LED. 8. Warms up and GPR LED turns on every time for 60-120 sec like it is supposed to. Could this be related to the stalling issue? I mean ... maybe CPU? We look for any ideas help from any of you. Hope my explanation clears the air so we can narrow the options in fixing the issue. |
yea that is literally the same . it seems like my truck is stalling more often as the days go on. i checked the fuel filter , it is dirty but doubt thats the problem. and as of your new GPR and GP's i dnt kno if that could somehow be related. mines doing exactly the same and i have done nothing new to it lately. idk. google guzzle 7.3 cps. i think were having the camshaft position sensor problem.
Sorry, meant to post this about an hour ago.
Yes, both of you need to replace the cps. It may not solve the problem but it sounds like it is the problem. @ xory72...i would check to see if the pcm is commanding the gpr to turn on when it is cold. Just use a test light on the small wire going to the relay. If it isnt, i would check the EOT sensor for an open (could be shorted) when under a certain temp. I am pretty sure the EOT sensor is what the pcm uses to see if gp's are needed. If the sensor is bad but only in certain areas it may cause this. This is only a guess and i want you to test and not replace till you find whats going on. |
