Dusted engine?? - Ford Powerstroke Diesel Forum
Old 05-15-2012, 05:08 AM
Dusted engine??
Have posted this on powerstrokenation.com as well but thought id ask you guys....
I am in a pickle and need some advice. I have bought a 2000 F250 crew cab from a damaged vehicle auction to import as parts to Australia.
Anyway it was a high mileage (268k) truck that had a bad repair from a hit in the side. I need everything for a conversion i am doing so regardless of the engine i was going to buy it any way, But i hoped it would run. It has to be pulled apart to come to australia but when i asked the guy that is pulling it apart if it ran this is the reply i got (its not my spelling it as he wrote it);
Have spent over 3 hours trying to start your F 250 and the only way it will even try to go is with starter fluid and when it runs out it stools out. The air filter was not seald so my guess is the motor has been dusted. That means it has had a lot of dust taken in to the motor through the air filter pipe line. Also the way it hunts when I Reyes to start it as if it was trying to run on.
This is also a sign of the motor being dustered
then i as him what he meant, and got this;
The truck hunts when trying to start does not wind over evenly sounds like
> it has different compression in one or more cylinders
he also said on a phone call that the turbo and intercooler were full of oil so the truck may have been rolled at some stage or would this happen from sucking dirt?
So i had him pull it apart anyway thinking i will figure it out when it gets here, but wouldnt mind some of your thoughts. Its going into an earlier truck so will be rewired.
should i?
put it back together and test it myself? or rebuild it while its out (was going to do this anyway but wouldnt mind testing the truck first)?
some photos;
Old 05-15-2012, 08:18 AM
Now would be a pretty easy time to do a compression check and you'd know for Sure if you had that kind of problem. Could be several things causing what you describe that would Not be a huge issue...
I wouldn't be at all concerned about the oil in the Turbo & IC, they way the Crank Case Ventilation works in these engines, they All collect oil in there.
Old 05-16-2012, 01:28 AM
Thanks for that.
first thing when it gets to australia is a compression test, then go from there.
Old 05-16-2012, 03:28 AM
yep as NoRalPh said, a comp test would be the first thing to do especially if the dumba.. was trying to start it alot with starting fluid. Starting fluid isn't very good on a diesel.
There are quite a few things that can cause the engine to act that way and not just bad compression.
As far as the oil, i agree it is pretty common and doesn't indicate the truck was rolled! lol
I would also try and use as much of the newer truck electronics as you can. the newer 7.3's have bigger injectors and different tuning compared to the earlier 7.3's
Old 05-16-2012, 03:35 AM
its going into one of our aussie 1987-91 trucks so all the electronics will need to be transfered, a mate has done same thing so will copy his. Loom has to be lengthened about 4 foot for right hand drive, this is why i wanted the engine running before we start so we know its going to run
