2000 F350 dies intermittently - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-08-2006, 05:53 PM Thread Starter
Have a friend with a 2000 F350 with the 7.3 PSD.
Has 175K on it, and basically runs great. Plenty of power etc.
Last couple of days however, he can be driving down the road and it will suddenly die... sometimes it will start right back up, other times it may take 10-30 minutes to restart. Hooked it up to the scantool tonight, no codes, no pending codes. Went to go to test info, and it said that test results would not be valid because it hadn't completed one drive cycle... thought that was weird, looking at data, and all of a sudden it died... when it did, the scan tool wouldn't communicate with the EEC... wouldn't restart either... after about 5 minutes, it would start and I could connect to the EEC again... no codes. It appears like the EEC is losing power somehow... is there a common problem that could be causing this?
Thanks,
Dave
n5xmt is offline
post #2 of 5 Old 07-08-2006, 05:56 PM
i cant entierly explain the scan tool communications issue.....but it sounds like a VERY typical cam sensor failure to me......
mschn99 is offline
post #3 of 5 Old 07-10-2006, 08:00 AM
PowerStroken090's Avatar
Any mods? I had a corrosion issue between the computer and an aftermarket chip. Usually a bump in the road triggered the effect and the truck would die. fortunatly though, she'd re-fire rather easily.
Steve
PowerStroken090 is offline
post #4 of 5 Old 07-10-2006, 08:36 AM Thread Starter
Still bone stock.
n5xmt is offline
post #5 of 5 Old 07-10-2006, 09:04 AM
PIPE HITTER
gcop's Avatar
I would agree. Thats a common problem with the 7.3's, the good thing is it's a quick and easy fix.
"Life is hard, it's even harder when you are stupid"
gcop is offline
