Valve cover replacement? - Ford Powerstroke Diesel Forum
Old 04-26-2012, 06:54 PM
Hello i noticed a leak coming from my valve cover in the front nearest to the PS pump and looks like its the seal. I know they have clips and what not but is the change over to new gaskets that difficult? How long should something like this take? I have a few leaks i am trying to address and would like to get it done this week. thanks guys?
Old 04-27-2012, 06:17 AM
Be sure it's actually coming from there and the bolts are tight, VC gaskets leaks aren't common. If it IS that gasket, it's a little more complicated than Any other VC gasket you're likely to have done That gasket contains the electrical plug, on each side, to control the Injectors & Glow Plugs (so it's not cheap..). You're talking about the drivers side, that's the easy one to do, you won't have trouble
