Oil Fountain... - Ford Powerstroke Diesel Forum
Old 04-10-2012, 07:11 PM
Once you go black......
Send a message via MSN to CanadianDiesel
Unhappy Oil Fountain...
Was on my way to pick up my date tonight (perfect timing right!) when my old man calls me and says there's a huge puddle of oil from where my truck was parked in the driveway
I pull over right away, sure enough oil is pissing out at a decent rate.
It's back in the driveway now, I still had oil on the stick, and it's leaking from about a foot behind where the drain plug is.
I'm not driving it to work tomorrow, and not taking it to Ford YET. Just looking for answers... I will try to get pics of it tomorrow and locate an exact location of leak, and perhaps you guys can diagnose what it is if I'm lucky. Then I'll decide if it's going to the dealer or if I'm tearing into it....
-Matt
Old 04-10-2012, 08:23 PM
Is it coming from the inspection plate? look in the valley and see if you can tell if its coming from somewhere up there
Old 04-10-2012, 08:54 PM
check the valley.. my oil leak was about a foot behind the plug too and it ended up being a leaky pedestal and the ebpv was wet too
Old 04-11-2012, 03:55 AM
Thanks for chiming in guys, Before work I had a look and there's definitely lots of oil in the valley; fresh oil. So you think Pedestal?
Old 04-11-2012, 04:22 AM
or hpop lines or hpop itself
Old 04-11-2012, 09:21 AM
Or ebpv
Sent from my DROID BIONIC against my will
Old 04-12-2012, 06:26 AM
It's looking like HPOP or its lines.
Old 04-12-2012, 07:11 AM
To get to the HPOP, I need to get a couple things out of my way, what should I know before taking out the fuel filter assembly?
Old 04-19-2012, 11:42 AM
ALright, she's fixed. Turned out it was an HPOP line O-ring fitting, and apparently the ICP was done. If the ICP was shot, shouldn't it give me a Check light?
Total, 700$...I need to learn more about my 7.3
