Oil leak around oil pan, maybe dipstick - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-09-2012, 04:53 PM Thread Starter
99F250SD7.3's Avatar
I think I'm leaking a lil oil around where the dipstick enters the oil pan. Anyway to fix this?
SOLD - Early 99 7.3 4x4 ECLB F250/35" General Red Letter Grabbers on 18" Eagles/DIY Intake/Leveled/HPX/4" TB exhaust to 5" tip/Glowshift gauges/PHP Tunes
99F250SD7.3 is offline
post #2 of 5 Old 04-09-2012, 05:05 PM
I had to replace oil pan in my old truck with a 7.3l. they r prone to rust out. If u clean the pan really good and put some Gb weld around area it should work. Replacing oil pan is alot of money and labor. Ive seen gb weld do wonders.
oilfieldtrash6.0 is offline
post #3 of 5 Old 04-09-2012, 05:28 PM Thread Starter
alright I'll give it a shot. I gotta make sure that's where it's leaking. I'm pretty sure it is, the other day I wiped it all off and it looked to be clean toward the front and higher than the dipstick tube.
post #4 of 5 Old 04-10-2012, 09:25 AM
audiocontr's Avatar
DANGER! Read up on this before you go poking around.
Its a simple o-ring replacement that can have disastrous results if not done properly. Search you-tube for a video on how its done and precautionary measures.
Nonconformist. Functionality over bling.
My three rules for 7.3l troubleshooting: 1) Replace CPS and keep a spare. 2) Replace FPR and know your fuel pressure. 3) Hook it to a scanner and check for codes.
audiocontr is offline
post #5 of 5 Old 04-10-2012, 05:02 PM
xraypipeliner's Avatar
I think my oil pan is leaking from the gasket in front. What can I do to tell for sure?
2003 7.3 4-door Long Bed DRW
American Force 22" Classics on 33X12.5X22
Irate Diesel Competion fuel system
Rancho RS9000XL Shocks
PHP Custom tunes
Foil Delete
ZooDad Mod
aFe Stage 2 XP CAI
MBRP 4" Turbo back S.S Dual Exuast
Edge Insight CTS
Stancor GPR
Directed Smart Start
Kenwood Dnx 7160 W/Kicker L-7
Too many Recon lights to list..
07 H.D Front End Conversion W/ HID's
08 Tail-Gate
Roll Pan
S366 t4 mount
SRP 1.2
250/200's
xraypipeliner is offline
