blowing white smoke - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-07-2012, 08:45 PM Thread Starter
RossWM's Avatar
blowing white smoke
the truck has been blowing a steady stream of white smoke, i thought it must be oil but a diesel mechanic said it smelt like unburnt fuel and he thought fuel must be getting past the injectors and into the cylinders. Does that sound right? if so should i replace the injectors?
also theres oil in the turbo the mechanic i talked to said he had heard theres a seal on the hpop that goes bad that will cause that but he wasn't sure does anyone know for certain?
RossWM is offline
post #2 of 13 Old 04-10-2012, 01:47 PM Thread Starter
RossWM's Avatar
had a friend come out and one of us hit the throttle while the other one watched the exhaust, when you lay on the throttle it blows out clear so its when its idling that its blowing smoke, he says he thinks the smoke looks blue but i dont know to me it seems white
RossWM is offline
post #3 of 13 Old 04-11-2012, 01:34 AM
6chevy9's Avatar
im having a similar problem with my truck and was told it was most likley my injector o-rings. i bought a kit to replace all the o-rings on all 8 injectors for 57 bucks on ebay they are alliant brand. ill be doing mine this weekend ill let you know if it helps me out.
also if you have a scan tool like snapon or a few other expensive brands you can do a contribution and buzz test. it sounds to me like you just need o-rings from what i have been told / read about online.
E99 eclb 4x4 powerstroke with 6 speed trans really beat up with 480k on the dash and supposidly 140k on engine.
6637 mod
Foil delete
NGT Extreme batteries
6chevy9 is offline
post #4 of 13 Old 04-11-2012, 03:53 AM Thread Starter
RossWM's Avatar
ok thanks let me know how it works out
RossWM is offline
post #5 of 13 Old 04-13-2012, 01:00 PM Thread Starter
RossWM's Avatar
looking at fuel injectors and where can if find the date on the truck to see if its 99 or 99.5? I know theres a sticker on the door but the doors are off a different truck so where else can i find it? And after what date is it considered a 99.5?
not going to buy injectors till i'm sure it needs it, just want to make sure i buy the right ones the first time if i have to
RossWM is offline
post #6 of 13 Old 04-13-2012, 01:06 PM Thread Starter
RossWM's Avatar
just poked my head around and the sticker on the valve cover says 16 dec 99 so is that 99 or 99.5?
RossWM is offline
post #7 of 13 Old 04-13-2012, 01:13 PM
BigRed6.0L's Avatar
that would be a later build 99. 99.5
BigRed6.0L is offline
post #8 of 13 Old 04-13-2012, 04:06 PM
Myers129's Avatar
youll have oil visible in your turbo unless you do a ccv mod to keep the oil mist being vented from going through your turbo and intercooler. i would start with orings on the injectors and keep your truck as far away from the mentioned mechanic as possible. the HPOP doesnt come anywhere close to pumpin oil into your turbo. How many miles are on your truck? original injectors?
2000 f550 crew cab 4x4 w/ utility bed
regulated return w/ bowl delete, 4" straight pipe, stage 1 single shots, DIY 6637, adrenaline HPOP, DP tuner F6= 80 econo, 140 aggressive, 140 extreme, towing tunes, 22.5's w/ super singles
Myers129 is offline
post #9 of 13 Old 04-13-2012, 05:00 PM Thread Starter
RossWM's Avatar
270,000 miles, as far as i know they are the original injectors
RossWM is offline
post #10 of 13 Old 04-13-2012, 07:51 PM
Myers129's Avatar
In sure guys have gotten more miles outta injectors but i only got 115k from my first set. I would say if you have time to do it twice try o rings first and then Plan on settin money aside for injectors if that doesn't fix your problems. Does the truck run smooth and start fine still? If it sits overnight is there a large plume of smoke when it first fires?
Myers129 is offline
