Fuel leak - not from filter - Ford Powerstroke Diesel Forum
Old 03-31-2012, 09:29 AM
I have a 99 F-350 with a 7.3L. There is a fuel leak from somewhere behind the P/S pump. The 2 fuel line running thru that area appear dry.
Old 03-31-2012, 09:47 AM
Feedback Score: 8 reviews
Are you sure it's not running down from farther up on the engine? Gotta look real hard cause there's alot of "stuff" in the way.
Old 03-31-2012, 09:50 AM
Wash engine yesterday so I could look at it today. Top of engine is dry. Don't see anything leaking till I shut off engine.
Old 03-31-2012, 09:55 AM
Check the fuel lines really good cause one could be vibrating enough to rub on the corner of the engine/head casting or somethin like that. There may be a crack or rub through spot there somewhere.
It only leaks after it's shut off?
Old 03-31-2012, 10:08 AM
There is a section of those line that I can not see as they pass behind p/s-alternator bracket. But the lines are dry as they emerge, but fuel is running down block and dripping back by oil filter (truck is parked on incline in driveway).
Old 03-31-2012, 10:11 AM
Hmmmm......I've never really paid attention to what's going on right there with the fuel lines. Is there any connetions anywhere to ease removal/installation that could be leaking? obviously not. lol
Old 03-31-2012, 10:14 AM
My next step would be to remove alternator and p/s pump bracket to see what happens behind them.
Old 03-31-2012, 10:16 AM
So you're thinkin there's a leak back there that's squirting fuel on the engine but not running down the lines? Not very likely
Old 03-31-2012, 12:00 PM
I would think if you cant see what is going on but know the location, it is indeed time to clear a little junk out of the way to see a little better.
Let us know what ya find!
Old 04-01-2012, 04:39 AM
Pulled the bracket off. Fuel is coming from a freeze plug in the front of driver side head.
