Check this out: oil pressure gauge, possible issues? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-19-2012, 03:57 PM Thread Starter
Toms01PSD's Avatar
Quoted: 64 Post(s)
Info: 01 7.3 116k miles, auto trans.
Lately i've been annoyed by the oil pressure gauge in the dash. When I go out in the morning and start the truck, it turns over and cranks up just fine. It'll run for 1-3 seconds before the needle on the oil pressure gauge moves and the low oil pressure light will stay on with it. It's been getting progressively worse over the past few days also. Today I decided to try something so here's what I did: I would start the truck, let it idle for a second, then shut it off. I did this 5 or 6 times and it got to the point where the oil pressure needle would move before the truck would even crank up. I also noticed that the tach needle would move up a few hundred RPM's. I kept starting the truck over and over and each time the needle would jump up to normal oil pressure before the truck started. So here's my question, what does this problem sound like? LPOP? The gauge? Or something else? I've had help from one guy on here (thanks Nick) and i'm going to install an oil pressure gauge to see what i'm getting but i'd like to know if anyone else has had this problem or knows of a 'fix'.
I will also mention that the truck has 0 problems running, doesn't seem rough at idle or anything. Still maintains 15-17 mpg and she seems fine.
Tom
2001 F250 7.3 auto 4x4 Lariat CCSB
6637 intake
4" MBRP exhaust
PHP tunes
Foil delete
EBPV delete
ISSPRO Boost, Pyro, and Trans Gauges
Strictly Diesel Pre-Pump Filter/In-Tank Kit
Strictly Diesel Regulated Return and Fuel Bowl Delete
High Flow Banjo Bolts
Nitto AT's 305/70R16
2009 Pontiac G8 GT
Intake, Exhaust, Tune
Camaro 20's, Camaro SS Brembo's
1997 VDub Passat GLX VR6
Toms01PSD is offline
post #2 of 7 Old 03-21-2012, 02:40 AM Thread Starter
Toms01PSD's Avatar
Quoted: 64 Post(s)
No one has a similar issue or heard of this?
Tom
6637 intake
4" MBRP exhaust
PHP tunes
Foil delete
EBPV delete
2009 Pontiac G8 GT
post #3 of 7 Old 03-21-2012, 04:18 AM
jesilvas's Avatar
Quoted: 3 Post(s)
Mine does it.
The gauge is almost an on/off gauge, no real pressure reading to it at all.
The LPO system doesn't hold it's pressure once it's not running. So you have to crank to bring the pressure up. And the LPO sensor is in the HPOP reservoir. So since the HPOP is using oil out of the reservoir, it takes a little bit for the LPOP to fill it back up and raise the pressure in there. It's no big deal.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 7 Old 03-21-2012, 01:34 PM Thread Starter
Toms01PSD's Avatar
Quoted: 64 Post(s)
Originally Posted by jesilvas View Post
Mine does it.
Isn't there a check valve/ball that's supposed to stop it from leaking back? The thing is, if this issue didn't happen before and it is now, you'd think that either 1. the LPOP is getting warn out/going bad or 2. the sensor is going bad.
Know what i'm getting at?
Tom
6637 intake
4" MBRP exhaust
PHP tunes
Foil delete
EBPV delete
2009 Pontiac G8 GT
post #5 of 7 Old 03-21-2012, 03:02 PM
jesilvas's Avatar
Quoted: 3 Post(s)
I hardly pay attention, but to me, I think it's always been that way.
Only way to really tell is get a real gauge on it, like you said. Cause you can still have pressure and the dash gauge show 0.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 7 Old 03-21-2012, 07:54 PM Thread Starter
Toms01PSD's Avatar
Quoted: 64 Post(s)
Pay attention to it next time you start it and see what happens. Mine almost feels like it runs different when the pressure gauge finally jumps up.
Tom
6637 intake
4" MBRP exhaust
PHP tunes
Foil delete
EBPV delete
2009 Pontiac G8 GT
post #7 of 7 Old 03-22-2012, 04:11 AM
jesilvas's Avatar
Quoted: 3 Post(s)
No, I mean before. It does what yours does right now, and has for a while. I notice no difference in the running of it.
4R100, 2wd
330,000 + miles
jesilvas is offline
