Blown injector driver fuse
I have a early 99 F350, about a month ago it died on me while driving, like the key was just turned off. I found the injector driver fuse was blown. I replaced it and it started right up and ran fine. Then My son was driving it and it did it again so he towed it home. I replaced the fuse now it blows when the key is turned on. My question is where is the injector driver located and has anyone had this problem.
not sure if this is what u r looking for but the injector driver module (idm) is located behind your driver fender. tou eill need to remove driver wheel and inner fenderwell and it is tucked right up about where the emblem is . good luck hope this helps
Found the problem it was the fuel heater. I should have done a search first. Thanks.
