HPOP leak help - Ford Powerstroke Diesel Forum
Old 02-27-2012, 07:53 PM
HPOP leak help
My hpop is leaking on the back cover that is snap ringed in, there is a oring in there, who sells these Orings and, is this normal?
Old 02-28-2012, 06:35 AM
Should be able to find it on here, I would think.
Replacement O-rings for Ford Diesel Engines
Old 02-28-2012, 04:46 PM
Thanks, but they don't seem to have it either, can't seem to find this
Old 02-28-2012, 05:12 PM
Dieselorings.com has it are you sure it is leaking their? I thought mine was to, I bought the oring as well as the 7 others that come in a kit and the mounting gasket. All from dieselorings.com. When I got my hpop of I could not get that plate off after I got the snap ring off. Put it ll back together with all gaskets and orings except that one on the rer plate and no more leaks. I think it was leaking from the mounting gasket and oil was getting blown back up on the plate.. Hope this helps!
Old 02-28-2012, 05:17 PM
Found it on there! Thanks guys have all orings coming, yes it's leaking there, it's a reman pump with one hour on it and I can't get it warrantied, I have the plate off thanks again
