WASTEGATE PRELOAD ADJUSTMENT - Ford Powerstroke Diesel Forum
Old 02-12-2012, 05:36 PM
Hi All.. Can anyone confirm the correct procedure to adjusting the wastegate actuator preload?
I am replacing mine with OEM.
The Ford service manual says,
"hold actuator arm closed ( towards actuator). Use 5 PSI and adjust arm to slide over pin free".
I read elsewhere that you want to use 15 PSI instead of 5 PSI.
Which is the right procedure for a OEM replacement?
Thanks in advance, Jeff
Old 02-16-2012, 12:48 PM
anyone have a clue?
Old 02-19-2012, 10:04 AM
I'd trust the Ford service info.
