Truck started running rough, like not running on all cylinders, them shut off - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-10-2012, 02:41 PM Thread Starter
live for the now
ZombieSoldier's Avatar
Ok it's a sunny 48* here in Colorado. I was driving home from work, an she started running real rough like it was only running on 7 cylinders and got about 1/4 mile before it wouldn't go over 15mph. So here I sit in a parking lot trying to figure out what's going on. If I start the truck it runs real rough and shuts off.... HELP!!!!
2008 F250 6.4 - a little of this, a dash of that and soon you have made a truck the way Ford should have made it!
ZombieSoldier is offline
post #2 of 6 Old 02-10-2012, 03:01 PM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
Try draining your fuel bowl. When did you last get fuel? Is your tank low??
Sent from my PG86100 using Tapatalk
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #3 of 6 Old 02-10-2012, 03:06 PM Thread Starter
live for the now
Just done less than 3000 miles ago for fuel bowl, filter, and o-rings. Has just under 1/4 tank. I just started it again and it runs fine and I drove the rest of the way home with no issues. I have to get this fixed though as I move from Colorado to Georgia in 9 days
post #4 of 6 Old 02-10-2012, 04:30 PM
Quoted: 133 Post(s)
Feedback Score: 3 reviews
Pull your Valve Covers and take a good look at the UVCH connectors. They'll do that, make an intermittent bad connections to the injectors.
You can usually fix this connection yourself. -> 50 cent mod - Ford Truck Enthusiasts Forums
And a good overview of the problem -> http://www.youtube.com/v/GHwjEfJtM_g&hl
NoRalPh is offline
post #5 of 6 Old 02-10-2012, 06:04 PM Thread Starter
live for the now
ok so check this out.... my buddy brought over his SCT tuner to see if i have any codes. this is what we found:
P0237 turbo boost "A" circuit low
P0713 Trans Temp Circuit high open
P1281 ICP Sensor circuit high
P1394 Glow plug circuit high
P0123 Throttle pedal position high input open
P1690 Wastegate solenoid circuit
P0500 Vehicle Speed VSS
P1670 Electronic Feedback signal not detected
P1316 injector driver module not detected
P1212 injector control pressure lower than desired (engine crank or run)
P0236 Turbo boost"A" circuit range performance
P1211 injector control pressure higher/lower than desired (engine running)
P0720 output shaft speed sensor circuit
So what the hell is going on with my truck?????
post #6 of 6 Old 02-10-2012, 09:33 PM
Winning DUHHH
Quoted: 8 Post(s)
Id erase the codes, and drive for a bit to see if any pop.back up
6637
Wicked Wheel'd,
Southbend
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
Dont Tread on Me
