2001 7.3 engine replacement - Ford Powerstroke Diesel Forum
Old 02-05-2012, 05:16 PM
A friend of mine just got finished replacing the 7.3 in my 2001 supercab last week. The old engine was 150 psi or so low on compression on 1 cylinder. (Had a bad hose between air cleaner and turbo.) The engine we put in is out of a F450 with 160000 miles. He got it running and seems to have 1 cylinder with a miss. Lot of white smoke out of the exhaust. He used the injectors and glow plugs out of the old engine which have only 2000 miles on them. He buzz tested the injectors and they are good. Ohm checked all wires to injectors and apparently is ok. He gets a code for Injector drive module, but this was replaced last summer too, about 2500 miles on it. All the sensors were used off the original engine. Any good ideas? Main computer? He thought the main computer could be damaging the IDM?
The more money I have to spend on this truck the more I like my 92 6.5 chevy. Other than an engine at 300000 it is way more reliable than this Ford at 112000.
Why did it need the front axle totally redone at this low mileage? My Chevy didn't need anything until over 200000. I can't believe all this electrical crap on these Fords. If I ever get it running good it's going down the road. I've spent well over $6500 on this truck not including this engine.
Old 02-07-2012, 05:51 AM
Get a 01 DMAX and have at it, nothing's mechanical anymore if you want to compare get a 92 7.3 IDI
Old 02-07-2012, 02:53 PM
So tell me why the front end needed rebuilding so soon, and I know lots of Ford owners with the same problem.
Old 02-07-2012, 03:37 PM
Feedback Score: 5 reviews
I smell..... Troll....
Old 02-07-2012, 03:52 PM
Why don't you just answer my question?
Old 02-07-2012, 05:17 PM
All I'm sayin is a 6.5 is far from a 7.3 psd in technology, more comparable to a 7.3 IDI if you even want to say that. I've worked on 6.5 and 6.6 DMAX along with 7.3 and 6.0 and a6.5 is far from any of them that I listed
Old 02-07-2012, 05:20 PM
Sounds like bad hole
Old 02-07-2012, 05:25 PM
That question wasn't meant for you, it was for ToMang07.
I guess I'm just getting a little tired of pumping cash into this thing, which is why I didn't go for a reman engine. It will be a nice truck if I get it running decent. This blue smoke at idle is just bugging me. The truck didn't have an easy life before I got it. I may be able to get some of the money back on the engine if it's bad, but probably not any of the labor. This engine came out of a Caterpillar dealer service truck that got the cab tore off by a payloader. It probably had pretty good service coming from a diesel dealer. Maybe sitting around 2 years didn't help it any. I may try some Lucas Oil Stabilizer with the oil. It has CaseIH 10w30 oil in it for now. Maybe 15W40 will improve it? Don't mean to sound bit??y, just looking for advice. Thanks.
Old 02-07-2012, 06:06 PM
Do NOT put lucas in it. It messes with the HUEI system.
I would do new fluids, and I would run 15-40.
Time to find a good scanner and see if anything comes up. Did you check compression before installing the new engine?
Old 02-07-2012, 06:42 PM
We couldn't do the compression test, engine was already out when I bought it, should have done it though, I guess after installing and removing injectors. May still have to do that if it doesn't clear up.
I'll probably put some miles on it and go to 15W40 oil. He's using a Snap On scanner, not sure of the specifics on it.
Thanks1
