ok i have a leak somewhere help - Ford Powerstroke Diesel Forum
Old 01-26-2012, 06:41 PM
ok i have been hearing this ticking leaking sound and i was told it could be my up pipes but i looked and i dont see soot around my turbo and it dose not look like its leaking. everything still runs fine its just down on power from what i rember
is there any other places i could look for a leak?
oh and you can only really hear it "ticking"/"leaking" when its not at an idle
its a 01 f250 293k miles never had a chip on it just the resistor mod that i dont use alot.
Old 01-30-2012, 04:22 AM
ever changed valve cover gasket? could be in your boots if it is a "hissing" sounds. "ticking" i would lean more towards valve cover gasket or possibly a weak lifter. could also try adding some lucas additive to the oil. let me know if you figure this out!
Old 01-30-2012, 04:27 AM
I'm taking to the dealer to get a diagnosis ill fill you in thx
Sent from my Nexus S 4G using Tapatalk
