Failed buzz test and codes
Trucks been making a "ticking" sound coming from drivers side bank. Can only describe it as it sounding like a gas engine with a loose rocker arm. only would do it between 25-45 mph at first and around 1700 rpm. Now does it at idle just not as loud as when its at 1700rpm.Tried running buzz test but all 8 cylinders failed. Tried unplugging injectors individually as engine ran but no change it sound. checked all connections to under valve harness and all seemed good.
Codes:
P1670 Electronic feedback signal not detected
P1316 injector drive module codes detected
P1247 Turbocharger boost pressure low
P1248 Turbocharger boost pressure not detected
Reason: corrections
