another no start issue-cranks and starts sometimes - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-22-2012, 04:24 PM Thread Starter
ok,so ive replaced the cps a few times. it seems like that maybe the issue. how much should my rpm gauge move when i crank it over?
if its not the cps and will fire if i charge back up the batterys,what would cause this?bad IPR?
00 F250 auto 6" lft/37" toyos,riffraff frx,riffraff hpx,riffraff plenum inserts,riffraff IC couplers,riffraff AIH delete,riffraff pre-filter,GS gauges,turbomaster WG,WW,DIY intake w/AFE bigboost,tru-cool tranny cooler,magtec tranny pan,BD diesel built tranny.
outlawpsd.com
nation is offline
post #2 of 4 Old 01-22-2012, 08:48 PM
Have you scanned it for codes with a good scanner? Not some cheapo scanner
mgassel is offline
post #3 of 4 Old 01-22-2012, 10:57 PM Thread Starter
i have a scan gauge 2,aeroforce and snap on scanner. i get the same 3 codes,all which are associated with my WG delete,aih delete and code that tells me im throwing codes.
outlawpsd.com
nation is offline
post #4 of 4 Old 01-25-2012, 01:42 PM
Cjcross22's Avatar
How long ago did you change the CPS? Any other symptoms beside no start?
The RPMs will flutter slightly when it's trying to start.
Also you should get a code indicating the cam sensor is bad if that's the case.
-Cory
Y2K
F250 XLT 7.3L ECSB SRW ZF6 4x4
Cjcross22 is offline
