Electrical/start problem - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-20-2012, 04:49 PM Thread Starter
Hello Everyone,
This morning when I went to start the truck the WTS light and all other dash warning lights(op/low fuel ect.) did not come on.
The truck started fine(was plugged in) but no gauges where working either...just had it towed and mechanic called and said that they can't get it to do it again...wow..what a surprise!
What can cause this and where do I start looking?
Thanks,
Pete
truck is a 2000 psd /bone stock with 265,000 on it.
rayburn98 is offline
post #2 of 3 Old 01-20-2012, 05:02 PM
700xxmaniac's Avatar
Coulda been a wire or fuse that was lose.
99 ford f-250 crew cab powerstroke
-skyjacker 6'' lift
- 395-70r-16 mickey tomson baja mtz
-sct tune
-stright pipe (vrrrooom)
-cops are in love with the thing
08 TRX700XX
-uni
-primary drive 13t
-pclll
-cp 11:1
01 recon es 250
-kenda 22'' bear claw
-53mph top speed
700xxmaniac is offline
post #3 of 3 Old 01-20-2012, 05:23 PM
str8wkd's Avatar
could of been the modual that they use to make the remote start and locks and things work ( But not sure if one Is needed for a 2000) could be the second ignition on the remote start brain was loose
04 F350
Extreme Street tooon (By Eric)
Harley Lights
S&B cold air kit (lid delete = more air)
Sinister Coolant bypass
MBRP 4in straight piped
Alpine in dash tv,
Limo windows,
55watt hid headlights
35watt hid fogs
Smoked roof lights
Mephis audio highs
Sub box w/ Mephis Pr's
Edge Insight CS
Studded, Deleted, powermaxed
86 Iroc (slightly modded
) 383 stroker pro 1 alum heads 69 302 race cam 8 point roll bar frame connectors 350 turbo trans welds
str8wkd is offline
