New Here with Problems
I`ve had a few 7.3 idi powered Ford`s,but picked up my first 7.3 Powerstroke yesterday. It is a 2000 E350 van with 240k on it. I wasn`t afraid of the mileage. It seemed to run well,just slightly rough before it warmed up. It smoothed out,and I test drove it and all seemed ok.
I get it home,and go to take it for a ride a little later and it seemed to run a little rougher again,and was down on power. The CEL did not come on,and is/was not burned out. Today I went to start it and it took forever to get it fired,and when it finally did fire it ran very rough for a while,eventually smoothing out little by little,but never all the way. It did not however run as well as did yesterday,and struggled to go upto even 20mph. Still no CEL. After some research online I pulled it inside and pulled the driver side valve cover off and found the UVCH was a lil loose. I fired it up and it seemed to run slightly better,still no CEL light. I then spent 2-hours removing the pass side valve cover,and found that the harness on that side was also loose. It seemed to start a little easier,and seemed to run a bit smoother yet. But now the CEL is on. It still runs slightly on the rough side,and still seems a lil down on a power,but is running better then it was. Before I start throwing money at this thing (which I honestly can not afford to do),what would you guys replace first if you were in my shoes? I am thinking the UVCH & VC Gaskets on both sides and go from there. Last edited by FoMoCoPower; 01-18-2012 at 05:19 PM. Reason: forgot a word |
Well I would get it scanned since you now have a cel. I would also change the oil and fuel filter.
Sent from my ADR6300 |
Yeah,my buddy is bringing his scan tool home with him today. And was going to do the fuel filter while I`m in there.
It was sitting for atleast a year,it had over a half tank in it. I put a bottle of fuel additive in it (forget what kind). Might go get some new fuel for it today aswell. |
P1272
P1670 P0603 P1316 P0478 P0470 |
P0470 - Exhaust back pressure sensor circuit malfunction - Biased sensor, open signal return
P0478 - Exhaust pressure control valve high input - Plugged sensor line, stuck butterfly, restricted exhaust P0603 - Internal control module KAM error - Open PCM pin, disconnect B+, faulty PCM P1272 - P1271 - P1278 - High to low side open cyl. # 1-8 - Open circuit, open injector, failed IDM P1316 - Injector circuit/IDM codes detected - Injector circuit failure/IDM codes detected P1670 - EF signal not detected - Open/shorted EF circuit Not sure what all that means, but put it in so others wouldn't have to look it up!!! |
Well,some big progress...while trying to test the ohm`s on the injectors I discovered that the harness was not plugged into the #2 injector...runs much smoother now.
The UVCH`s were a bit loose when I first checked them,so I think I am going to buy the new harness` and valve cover gaskets. Has anyone ever seen an injector unplug itself??? |
Ok,I have been working on it on/off for the past week or so.
I replaced the cps,both uvch`s, (glow plugs since I was in there),fuel filter,drained the fuel tank/replaced with fresh fuel,fixed broken/loose starter cable,and changed oil/filter. It runs better,but still has a slightly rough idle at times,and bogs/stumbles on acceleration and blows white smoke out of the exhaust while doing so. The CEL is no longer on,but when scanned it still gives: P1670 P0603 P1316 P0478 P0480 From what I can tell,I need to clean or replace the EBP sensor/tube to take care of P0480/P0478 The other three I believe are pointing towards IDM issues. Do you guys think I need to replace the IDM? The injectors all OHM tested good,but I know that doesn`t rule them out entirely. |
