crank over but no start - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-16-2012, 05:43 PM Thread Starter
cranks over but wont start not injector or fuel problem in a 60 degree garage and ran fine other day any ideas?
1 ton stroke is offline
post #2 of 11 Old 01-16-2012, 05:46 PM
roche837's Avatar
Quoted: 5 Post(s)
Feedback Score: 4 reviews
Year, Engine? Lots of possibilities.......... Codes? Needed information for a good diagnosis. You can search un the upper left corner based on your symptoms and you should be able to find No Start checklists and a ton of info.
EMPIRE STATE STROKERS
Studded, 5" exhaust, Sinister EGR DELETE / Coolant Filtration, more to come
roche837 is offline
post #3 of 11 Old 01-16-2012, 05:48 PM
jesilvas's Avatar
Quoted: 2 Post(s)
IF it's a 7.3 -
Key on, engine off, does the WTS light come on?
While cranking, does oil pressure come up?
While cranking, does tach move?
Why is it not a fuel or injector problem?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 11 Old 01-16-2012, 06:23 PM Thread Starter
its a 2000 7.3 wts light comes on and its not a fuel problem cause it wont start or fire with ether
post #5 of 11 Old 01-16-2012, 06:24 PM Thread Starter
and no engine light or anything like that comes up
post #6 of 11 Old 01-16-2012, 06:38 PM
jesilvas's Avatar
Quoted: 2 Post(s)
I don't understand how that wouldn't be a fuel problem.
If there's no fuel to keep the ether going then that would be a fuel problem.
You could try the CPS. That is sometimes shown by no tach movement.
Is the fuel pump running with key turned on?
Does the HPOP reservoir have any oil? It should if the oil pressure gauge comes up while cranking.
You could check the UVCHs. They might've come loose.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 11 Old 01-17-2012, 05:00 AM Thread Starter
well when i spray ether in it it makes no diference it doesnt even fire so i dont think its fuel prblem im guessing it electrical like the cps censor or the #30 fuse
post #8 of 11 Old 01-17-2012, 05:20 AM
jesilvas's Avatar
Quoted: 2 Post(s)
The #30 fuse isn't it. You said it yourself.
That fuse handles the IDM, PCM, and fuel bowl heater. If it was out, or ANY fuse for the PCM, then you wouldn't have a WTS light.
Check what i said. You can't "think" it's not a fuel issue till you check all that other stuff.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #9 of 11 Old 01-17-2012, 06:23 AM
I'm not sure that's exactly right, when my fuel bowl heater fuse was blown I still had the WTS light. My question is, if you know that fuse is a possibility, why have you not looked at it yet? The internet is pretty good, but we cannot go look in the truck for you...you are going to have to put forth some effort.
slow96z is offline
post #10 of 11 Old 01-17-2012, 12:31 PM
audiocontr's Avatar
need to hook it to a scanner, plain and simple. You will pull your hair out otherwise. Call around and find a mechanic with a real scanner.
Nonconformist. Functionality over bling.
My three rules for 7.3l troubleshooting: 1) Replace CPS and keep a spare. 2) Replace FPR and know your fuel pressure. 3) Hook it to a scanner and check for codes.
audiocontr is offline
