Newbie here also a 7.3 issue - Ford Powerstroke Diesel Forum
Old 01-15-2012, 04:40 PM
Red face Newbie here also a 7.3 issue
Anybody know why it would just act like it was dying regardless of how much you pressd the gas? Check engine light came on, pulled over, restarted and it was fine. Weird.
Old 01-15-2012, 06:26 PM
Year, engine, something. We have nothing to go on.
Old 01-15-2012, 07:42 PM
Feedback Score: 5 reviews
Old 01-16-2012, 09:39 AM
sorry?
It's a 2002 F-250 super duty with a 7.3 liter diesel. Automatic tranny and 4wheel drive. It's a xlt Lariat model if that means anything. It just will die and even with the throttle mashed all the way to the floor it'll quit. I noticed one time there was a lot of smoke coming out of the exhaust but that was the only time. I changed the fuel filter and that seemed to help one time. I added some injector cleaner and that helped oone time but nothing helps all the time. Seems to be the slightest vibration in the steering wheel when driving also that wasn't there before. Any feedback will be appreciated.
Old 01-17-2012, 02:47 AM
Unapologetically American
Feedback Score: 4 reviews
Moved to the 7.3 section, to try and get you some more attention for you issue
Old 01-17-2012, 07:39 AM
Ok. Anything that helps.
Old 01-17-2012, 11:15 AM
Too many variables. Could be a lot of things
Has the CPS been replaced by Ford? Its under recall and should be replaced. That may fix your problem right there.
Next step is to have someone with a REAL scanner check for codes. The basic OBD-2 scanners at autozone will NOT work. Least expensive is an autoenginuity. If codes are found, they will lead you in the right direction.
If no codes are found but there is a weird bogging and it dies, check fuel pressure. You'll need a gauge to do this.
Searching on any of the above terms will lead you to all the information you need.
Old 01-17-2012, 04:21 PM
Question HUH
Don't know what CPS is but will have it looked into. Also will have Ford dealer run scan. Thanks
Old 01-17-2012, 07:47 PM
Welcome to guzzle's CPS R&R Web Page<
Old 01-18-2012, 08:11 AM
Thanks a ton. I will call the dealer ship and see if the CPS has been changed as they would have done it and go from there.
