Truck starts but then will run rough and shudder then stall. - Ford Powerstroke Diesel Forum
Old 01-14-2012, 02:39 PM
I have been having an issue latelly once in a great while where I will start my truck and sometimes it will idle and warm up then do this or right when I start it it will shudder and stall out like its not running on all cylinders. And it usually only does it when it is raining out.
Old 01-14-2012, 03:46 PM
check to make sure your windshields not leaking down in the drivers front corner and dripping onto your fuse panel, relays and pcm.
Old 01-15-2012, 09:48 AM
wait for a dry day start truck and slowly garder hose the truck from bottom to top front to back and make note when you get to an area where truck acts up.
