2001 7.3l Powerstroke No Power
i have a 2001 f250 w/ 7.3l. turbo won't spool up unless i put the pedal to the floor. i am not getting the greatest fuel mileage about 12-13 mpg(summer). is this a turbo problem, fuel supply problem, or injector problem?
should the turbo spool up when accelerating normally? also, when i start going up a hill (w/no trailer) instead of the turbo spooling, the truck will downshift and then the turbo will spool. |
I would start by checking your up pipes and intercooler boots for leaks, and physically remove the intake at the turbo and check the wheel for damage, and the shaft for play. It should spin freely and not move up/down/side-to-side very much. From there it would probably also be a very good idea to check/clean your EBP sensor/tube. Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page Good Luck, and
the only gauge i have is the boost gauge w/ exhaust temp. when i do get the turbo to spool i can only get about 16-18lbs.
| Tags |
| fuel supply, injectors, turbo |
